# Cutting problem
**URL:** <https://forum.arcdroidcnc.com/t/cutting-problem/5821>\
**Category:** General Discussion\
**Created:** [March 29, 2026, 8:24pm UTC](https://forum.arcdroidcnc.com/t/cutting-problem/5821 "2026-03-29T20:24:27Z")\
**Posts on this page:** 1\
**Showing post:** 3
<div class="post-metadata">
**Author:** ![bobplewajr](https://sea2.discourse-cdn.com/flex016/user_avatar/forum.arcdroidcnc.com/bobplewajr/32/156_2.png) [@bobplewajr](https://forum.arcdroidcnc.com/u/bobplewajr)\
**Post date:** [March 30, 2026, 9:34am UTC](https://forum.arcdroidcnc.com/t/cutting-problem/5821/3 "2026-03-30T09:34:28Z")
</div>
@vincent try grounding directly to your workpiece. Check out the link I attached showing the identical issue.
> [@170mm Flange 12mm Plate cutting issues](https://forum.arcdroidcnc.com/t/170mm-flange-12mm-plate-cutting-issues/4356/3):
> Also a good idea to ground right to your work piece if you are able to. The pic compares a cut on 5/16" that was grounded only through the table to a 1/2" sample that was grounded directly to the plasma cutter. Good Luck! +1
Good Luck!👍
_[View the full topic](https://forum.arcdroidcnc.com/t/cutting-problem/5821)._
