Hi all I’ve received my new ArcDroid plus controller over the weekend, and have it installed. I’ve a question regarding the Torch indicator icon - it used to be on the older version but I cannot see it on the new controller. Previously I used to switch the torch indicator on the screen to the off position , to perform a dry run. Then when I was happy with the dry run, would change the icon to on, and the plasma would start cutting.
How can I do this on the new controller? I have the stylus unplugged from the ArcDroid. However the stylus icon is remaining on (visible) on the new controller and it doesn’t allow the plasma to start cutting. What am I doing wrong???
Hi Thanks for replying When I remove the stylus the on/off for the torch is not visible. The stylus button remains on the screen as if the stylus is connected. When I manually hit the switch on the plasma it starts cutting.
Have you tried going back to the standard controller to see if there is the same problem? It might be a problem with the jack socket in the Droid’s base. I think they use an auxiliary contact on the socket that is opened/closed upon insertion of the jack.
Hi @BobD I’ve tried the standard controller and all works fine. When I moved over to the new Arcdroid Plus controller this option is still not visible. So I just don’t know what the issue is?
