I’ve just down loaded the latest Simple Trace software and Arcdroid Firmware. The Simple Trace loaded OK; however, during the Arcdroid Firmware update the screen displayed an EPROM mismatch error.
The Arcdroid Firmware completed loading and everything appeared to be OK. I then traced out a flower style pattern to cut out of 10mm plate. The trace looked great; however, when I run a test, the cutting pattern starts cutting out of sequence in odd places about halfway through the trace.
I’m not sure if the EPROM mismatch error during the firmware update is causing the problem or maybe my pattern is too complicated and exceeds the Arcdroid capabilities.
Any ideas to resolve the issue would be greatly appreciated.
