Why does my z axis run a fault code?
What are you doing when you get a fault? What does the fault say? We need more bread crumbs to help……
@johnny You probably have your “Z clear” set to high it basically hits the limit when lifting the torch up between cuts
You really only need to set it at something like 1/2 or 3/4 of an inch.
the head is also fully adjustable (screws holding the dovetail in place) so you can optimize the position of the head to get the best travel range for your set up.
AM<
