using a .125 gage block to set calibrate the Z axis, during the run the stylus is about .005 above the work surface when it completes it raises up to about ,062 and stops, no matter what dimension i i key into the probe offset it t doesn’t change
Replied to you 11 days ago on your previous post on this problem……
How about a pic of your Tune screen?
First make sure that nothing is interfering with the black cable going from the head back to the droid base. Make sure the cable sheath is seated into the black plastic hatch on top of the droid base. The cable going slack and the sheath releasing the microswitch under the hatch is how the probing works.
Set your clear Z to .5” Set your pierce to .2” Set your cut to .125”. Make sure the surface your touching off on is solid and not deflecting during probe.
Run your test and see what happens. You should be able to see the three distinct heights occur.
Stop it during the actual cutting portion and see how close you are to the gauge block.
I ran the test as you said, the movements were about 1/2 the distance as programmed, I changed the offsets for pierce and cut and it seems like it’s right where it should be, but I have another problem when I use the trace function the tracing doesn’t show up on the screen, just the start position to where the cut would start there is a short line on the screen to the cut position an that’s it
I take it your new to this. So lets start with basics
Turn Droid on. Hit home. Move arm to center of work area. Hit zero. Tap Trace. Select box for circle. Depress knob or click stylus. This establishes circle center at the same spot as zero. Dialog boxes open. Select D, enter 3”, hit check box. Tap Save, (looks like a floppy disc)
Tap load, file you just saved will be at the top. Select it.
You should see the circle on the screen. You haven’t moved the arm at all but hit zero anyways.
Hit run and it should go.
Try setting your cut height to .250” and see if your closer to “.125.
When you go to machine settings and change the offset, are you hitting the check box?
After test run and height didn’t change, go back to machine settings, offset, and see if the number you previously entered is still there or did it revert to something else?
I’ve never used the offset as it wasn’t an option in the early days of this. I just comped my height setting.
Do all this with the stylus. Eliminates torch cable interference. Make sure you have things set up with the Z working in its upper range of motion. Downward movement is gravity and spring pressure.
Make sure your Z is smooth and not sticky. With no sled on the Z head crank it all the way down with the black knob. Then by hand pull up on the cable sheath at the head and see if the move is smooth in both directions. May need a drop of oil on the rod bushings.
I have that part figured out, what I’m referring to using the stylus to trace a pattern, screen shows a line from point zero to cut position and as I trace around the pattern using the stylus in the arm nothing shows up on the screen except the short line from point zero to start cut position.
