Zaxis backlash calibration
Hello, I don’t know why I’,m not seeing the things the manual says I should be seeing I do home>zero>trace>shape>O press stylus button and I get a screen that says x:0.01 y:0.01 d 60.00 lead: 3.00 entry/ L cut.
I am nt seeing a screen with an option to chose a circle diameter. I’ve gone thru it 1000 times, I’m getting nowhere.
d=60 is your dia. Tap the box with 60, enter the number you want, tap the green check mark.
Ahhh ok, thank you sir.
