Hi - I have had my Arcdroid for a number of years and it has done a lot of work. Majority of it flawless. I have a couple of questions.
Is there a service document for these machines? Eg oiling, belt tension, dust extraction etc?
I am in Australia and I notice the new monitor has just been made available here. Other than the power supply issue, which I understand has now been fix, is there any issue with it? I have had a couple of files that it would not cut due to lack of memory and I understand the new monitor has 8x the old monitors memory? Has anyone had any issues?
I can’t speak to whether Arcdroid publishes a formal service document, so that’s probably one for their support — worth asking specifically for a maintenance schedule covering belt tension and lubrication intervals. On the memory errors: those usually come from file complexity rather than cut length, so try simplifying nodes, removing duplicate or overlapping paths, and joining open segments before exporting. If a file still refuses, splitting it into separate operations often gets it through. Regarding the new monitor, the extra memory should help most with exactly those dense files, but I’d confirm the current revision and power-supply fix directly with the Australian supplier before ordering.
Can I ask for more information about the power supply issue?
I purchased one of the first ArcDroids years ago but life got in the way so it’s never been used. Finally getting back to it now and trying to relearn.
@StevenM The Plus needed more power to operate than the Droid could supply and startup would fail. The fix was a booster plugin for the motherboard and limiting the screen brightness to 50%. Only drawback was if you have the laser stylus its brightness is also reduced.
Another issue you will face with an early Droid is the coms chipset is not compatible with the plus. This requires a new motherboard for the Droid and also a new input panel for the original controller so that you can still use it with the new motherboard. Arcdroid will supply these items free of charge and make things right. The Plus is certainly worth the effort!
