Just got my machine and ran into a problem. Sometimes when i run for example a circle it will run it multiple times, can’t seem to find where to adjust this or what caused this.
Has happened with the track&trace option as wel as with a DXF file.
When I have had this type of problem, it invariably comes back to my error. Especially when drawing shapes, I have sometimes ended up with two images on top of each other.
Same as Oldbike99 says.
If it’s a DXF, select the shape and move it to see if there is another one under it, then hit redo if there isn’t one there.
If there is anything under the image you can delete one of them.
Welcome to the community, not counting me, there is a wealth of knowledge here.
