so I have a fusion 360 cad file, I imported it to the droid but it isn’t in a workable area (the cut path is past droid home) how do I get it in the center of the material or in an area that I can stack multiple to cut?
this will be the first cut after getting it all together and calibrated! very excited
You need to reset the origin WRT your drawing
If importing a dxf one of the options inthe import dialog is “origin” tap that on until the drawing ois lined up as you like
If Bringing in G-code you can do the same thing by going to trace and choosing the transform button.
