CNC torch - Extended torch mount
Looking to upgrade to a PTM80 CNC torch. I currently have a standard mount which has one clamp. Has anyone tried using the one clamp and zip tying (through the existing bolt holes) the upper portion of the torch to stabilize the torch? The extended mount from AD is $75 and the mounts I found on ebay, which work on the standard mount, are $79.
Used the 3d printed brackets a couple times without issue. No discoloration or physical changes. Used PLA+ filament. If heat becomes an issue, I will try ABS filament. Standard hardware from “True Value Hardware”.
