I just mounted my ipt60 machine torch this evening and thought I would share what I came up with. It turns out the torch is just over 34mm so what popped into my head was the 34mm rifle rings I had laying around. The lower ring that clamped around the plastic was tight but did not require any modification. The upper ring needed a little sanding. I purchased a 9" picatinny rail segment and bolted that to the arc droid. I know there are pre made mounts on eBay for purchase, but this was a simple and fun project. Parts can be found cheap from Amazon. I still need to adjust the height and am still waiting on my X2 so I can finish my table. Any input or suggestions are welcome, thanks.
That is awesome
I love it
