Finished my cart with water table. Also just picked up everlast 102I. No flat metal in my shop is safe now;)
Nice table!! Care to share some dimensions?
I see that you have a Miller 375 Extreme too. I have a 375. Did you use it with the Arcdroid? How did you like it? The upgrade for more power?
Thanks!
The dimensions I can get for you.
I have currently only used the 375 Miller on the arc droid. It does ok so far. Definitely has limitations. Yes the everlast is an upgrade but I haven’t tried it with the arc droid yet.
I’m machining a mount that will centre either torch without running a recalibration.
flat metal I’ve used mine to cut out pattern on angle iron a low profile drill vice helps a lot
