I think I read somewhere no more than 32 gig is that correct and why would that be
I believe that over 32 gb uses 64-bit system and arcdroid must have 32 bits due too hardware issues and its operating system.
Ok thanks for the info I’ve only had the ark droid for a couple of weeks still working on figuring it out completely with the stuff I’ve done so far I’m not sure how I’ve lived so long without it
Rob Neilson
You can format larger sticks as FAT32 with a tool like GUIformat FAT32 and use them. I’ve heard of some having troubles with cheaper sticks but that’s likely because of a bad or poorly made stick. It’s worked on every 64GB and 128GB stick I’ve ever tried on any machine. I’ve been through at least a dozen over the years.
