@Andrew-
Reading through the forums, I read that there will be a change to make the Arcdroid’s range bigger. I’m wondering if you can share the specs of the new reach or range? I’m considering buying this machine for my maintenance shop, and will build a dedicated workstation for the Arc. Any rough dimensions that we can plan for?
Thank you!
I had not seen much but I suspect the initial range may be address the too large file sizes issue, more than the cutting dimensions. I could be mistaken though and perhaps it is both!!
