Primeweld cut60 compatible question
Hi! I purchased my Arcdroid during the Kickstarter campaign and at that time and purchased a Primeweld Cut 60 in November of 2021. My work is all travel and has been a hectic schedule up until recently so until a month ago I finally found time to open and start to put together my units. I’m now discouraged in reading that even at the time I thought the Cut 60 was a good unit for the Arcdroid, I’m now not sure. I read that it is on the not compatible list, but am unclear does that mean to use the THC its not compatible or is it even not to be used at all with the Arcdroid? I see others post that they are using it with no issues, but I am not sure if its ok or not. I don’t need the THC as of now, but do a few projects i mind to use it. I hate to purchase another plasma cutter, but may have to take the hit and do so. If that the case, what are some recommended units that cut 3/4” plate that doesn’t cost a fortune? I appreciate any insight as I’m a newbie……
I also bought a Prime Weld 60 when it was given 5 stars
Has anyone tried out the new CUT60 from Primeweld that was released in July of this year with their Arcdroid? It was supposedly re-engineered from the ground up to minimize noise and to make its overall performance better. I contacted Arcdroid and requested the unlock code for THC, and they denied giving it to me and suggested I stick with the auto leveling feature. I will stick to the auto level feature for now but would like to use the THC feature once a forum member or Arcdroid confirms comparability.
