Ok another question, i know i can change the orientation of a drawing on the screen but can and how do i just rotate the object say 90 degrees because the drawing is to big one direction
Trace function. Hit edit button. Look for “A” which is angle. Enter a value as in degrees you want it to move. It will rotate it from there.
Thanks for the tip, gotta be smarter than the average pickinick basket
Edit with simple trace and the parameter fieled labeled A changes angle orientation and is where you change in degrees. Ive always done 45 degree increments.
