Screen cable is it just a high speed ethernet cable. Just asking in case it gets damaged.
yup standard CAT6 cable Limited to about 6 feet long for good comms
So a longer cable not a great idea? I my screen is mounted on the table and it could use another foot or so.
@Arrowhead
Depends If you have an Arcdroid manufactured After Nov 22 it will have “V2” laser engraved above the cable port on the screen.
These have a much better comms chip in them than earlier ones and can go a lot farther.
If its a V1 (no engraving) then after about 6’ you risk possible data loss. I have done as much as 10’ but it’s not as reliable
Great, thanks I’ll check it out.
I am looking to do a really long ehternet cable like 20Ft minimum to play with the arcdroid screen while in the house, i live in florida my garage is crazy hottttt . I assume that would be ok?
