Sheet cam does it work with Arc Droid?
Does sheet cam export in the Marlin code that Arc Droid requires? I’m not having any luck with QCad/Cam at all.
I have been using Sheetcam with the Arcdroid for 18 mths or so and it has never given me a problem. So easy to save a Solidworks drawing as a dxf and then straight into Sheetcam for layout and cut order then one click to generate the gcode. Easy to layout multiple parts for a single cut file.
Thanks for the info.
What post processor did you use for ArcDroid?
I just use the Sheetcam post processor that is on the Arcdroid download page
what code if any can be used to turn off and on thc with rules in sheet cam
