@Andrew So I’m unclear on which file format to download to the Droid. Does the dxf file need to be run thru the post processor? Would the Gcode file be ready to use as is?
Hey @BobD
The G-code provided is ready to run on the ArcDroid
The dxf file can be imported directly to the Arcdroid and you can choose cut parameters in Simple Trace
You can also use the DXF with Fusion or Sheetcam or QCAD to create your own toolpath…
Thanks much for the quick reply. I’m much more a Simple Trace guy! I’ll give the scorpion a shot this weekend.
