I have a basic design in Fusion 360, the simulate shows the correct cutting path ie inside slots then outside. When import the d3f as a dxf and run the cut file in the arcdroid there are added tool paths. Any help would be great, hoping someone else here has already run into this issue. Thanks
one of the things Andrew has let me know is you should be using G code there is a download on the arc droid site for fusion 360 it was alot to figure out but once i got it figured out it makes it so fast and easy . He explaind it like this dfx is a dinno and g code is modern and what a difference i have seen hope it helps you I’m new to this cad thing but learning every day the more I do the more i pick up good luck !!
