Do not connect to AD before checking voltage while making a cut.
You can check with a digital multimeter. If it’s below recommended, then it should be ok.
Make sure to check polarity before connecting to AD.
Happy cutting
Happy cutting
So if i am understanding correctly 50:1 would maintain the voltage under 5 volts and 20:1 would be over 5 volts?
So basically i throw the dip switch 4 to see if the 65 mimics Hypertherm and monitor voltage before i connect to AD and if it goes over i connect the voltage divider that i purchased from AMP mechanic.
I’m not sure that the Titanium 65 can be adjusted but let us know what you find. Yes, 20:1 would be around 5V output. 50:1 will be around 2V.
If all you have is 20:1 and you don’t want to run wires from your output lugs for true raw voltage, adjust the divider you bought to around 5K using your multimeter then do a test fire and measure the output voltage. You can fine tune from there. Aim for around 2V.
I have the non adjustable version so if the dip switch doesn’t output 2v i’ll disconnect and install yours.
Thanks for the input
I’m going to show my ignorance here but here goes.
to test raw voltage what reading should i expect and would it be AC or DC?
Same question for the output of the voltage divider, should it be AC or DC?
thanks,
Mark
I just ran a long cut with Dip switch 4 up on the titanium 65 and it never went over 3 VDC, the average seems to be around 2.5 vdc.
it was hitting 3 VDC when i neglected to connect the ground very well, once i did that It was mid 2’s
I’ve been told that the voltage divider on the Titanium 65 is flaky so i’m going to install the divider from Amp mechanic
Hello I just fabbed up a water table on mine and have a Titanium 65 still in its box. I have a Langmuir in the cold barn so I bought an Arcdroid for the heated second garage because it was smaller. Sad, four garage bays and my cars and trucks are all outside. Still waiting on a response from Arcdroid for the access code to open THC. I have Amp mechanics voltage divider in hand. Even bought a second Titanium spare torch cable. Going to modify the spare torch to vertical and eliminate the switch to lighten it up. This way both torches use the same consumables and are easily available. Is the THC Titanium 65 combination working out for you? Are you using a coil with yours? I have read the splash up from the water can actually cool thin metal so they don’t warp so much. That should help if the THC doesn’t? How long did you wait to get your unlock code response?
Hello, old post, what were your results? Did you set din 4 toggle to up and keep it there? Has the amp voltage divider work for you that way or did you switch it to stock all down? Just getting tome to play and want to try the THC function.
I’m about to start this hopefully I can make a YouTube video seams to be very limited information on this set up
Please keep us posted on this. Curious about the 50:1 dip switch setting on the Titanium 65. I just got all of the components to set up my plasma table, but don’t want to cook anything in the THC if the voltage is off. Thanks for your help!
Ever get anywhere on this?
