Torch off between cuts
Hi everyone. My torch is staying on too long after a cut. What is the setting I adjust to decrease the amount of time the torch stays on after completing a cut?
Thank you
Gary
@GaryW
The Arcdroid will shut off the torch immediately after a cut.
It’s more likely a setting on you plasma cutter.
For instance 2T/4T or sometimes called mesh mode. this will keep the pilot arc firing even when you are not pressing the trigger (basically what the AD is doing)
