Using a Titanium 65 with arcdroid trigger wire harness. Arcdroid will engage touch into work piece and pierces material and then torch turns off and Arcdroid continued tracing pattern. I thought initially a ground issue and used a flap disc to clean the material at the ground clamp. Torch will pierce and cut one time then it will go back to piercing and cutting off. What do y’all think is going on?
Check air pressure during cutting older hoses caused mine to do the same thing
Plasma has to be on t2 and make sure all cuts are from inside out.
