Hello,
I have a problem with my torch it looks like. The torch does not light at every approach. He pauses in between, but carries out the next steps. I used the TIG holder file from the forum. Can someone help?
Edit:
Different File, same Problem. ArcDroids Cuts, Stops on the next step, Starts another Step and after a bit of cutting the torch went off… grrr
ArcDroid and Simple Trace are updatet…
Working Piece is grounded well. Nozzles/Elecrodes looks good.
I may still suspect the solenoid valve.
I will bridge the solenoid valve and replace the wearing parts again. I’ll give you more information!
Thank you
