Tree of life for old Circular saw blades
Adapted a tree of life DXF for use on a circular saw blade with a center hole of 20mm or less (5/8" to 34")
The Zero origin is the dead center of the hole
GCode made with sheetcam with a kerf of 1mm
Blade size 12" or 300mm but can be resized
Gcode has over 6000 lines so need to be in 4 parts for AD - just load and cut each part without moving the work!
TOL1.gcode (103.1 KB)
TOL2.gcode (78.7 KB)
TOL3.gcode (31.1 KB)
TOL4.gcode (90.6 KB)
tree of life.dxf (682.9 KB)
Very nice work! Thanks for sharing
how did you cut this g-code file into multiple parts? im trying to cut this logo for a friend but its to large, even when i bump the tolerances way up.
