@goril
Can you send us some video of what you are describing?
If you are cutting thin stainless that fast and that low (why so low btw?) then it is probably warping during the cut…Auto level will not compensate for this. It simple calculates the tilt of the material when flat and creates a level plane that it can follow. And based on the numbers you posted your plate started pretty level already.
In order to compensate for material warping you need the THC function. This requires a compatible plasma cutter with a 50:1 divided voltage output and an unlock code from us. but THC will move up and down to compensate for warped or warping material
