Am completely new to plasma cutting, but quite experinced in Fusion.
I can’t work out what settings my post processor carries across, and what i’m meant to manually set. I’ve tried google, but got some very conflicting info.
I have an R-tech P51d plasma, It’s set in “auto pilot”, and “CNC” mode and stops/starts as requested by the Arcdroid, but the air pressure and amperage settings from fusion seem to make no change?
Also the cut / pierce height, and pierce delay do not carry across from fusion, yet the feedrate and kerf diameter does?
Ah, Thankyou. So CNC mode is a bit of a misnomer. Basically the arcdroid just turns it on off. I will have a look at the plasma cutter. Presumably I can alter the air pressure and power settings, then just flick it into cnc mode.
