Hi guys
Does the arcdroid have a feature run from here
So if your halfway through a part and need to stop and then restart where it was paused at ,does it have this feature at all ?if so any pointers on how to use it
Thankyou
There is a button the the screen controller that enables / disables the plasma arc from firing - mostly used for dummy/dry runs. This can be used to enable the arc part way through a job as you describe. It’s a manual thing and you have to judge when it’s time to enable the arc but has saved me a few times.
Just start off in dry run mode and when the time is right press the button and cutting will commence from this point on.
I do this same trick, and if its something I made in trace, I just go back, select and delete cuts that I’ve already made.
Hi guys
Not Yet but it’s on the list!
