Calibration difficulties
That makes sense and I was not doing that. It makes a difference and I am at 1mm or less on my readings.
One other thing: When I raise the stylus after running down the first rail the arm will shift to the side a little bit. It’s as if there is some roughness in the movement that the arm is settling away from. I just watched the belt tension video and I’ll take a look at that. See what happens.
