Calibration troubles
I received the arcdroid about a week ago and have spent nearly 8 to 10 hours trying to get it calibrated correctly with no luck. Is there anyone in Florida with one that could please show me hands on how to calibrate and operate it? Any help would be appreciated.
Honestly, when I did it I had so much trouble calibrating it as well. Spent about 5-6hrs and could only cut ovals. Anyway what I did to change that was when it said to switch over to the plasma cutter and calibrate with that, I left the pencil in and it calibrated it very precisely. Try that and see how it goes.
I may, Where ya at ?@jesse95
I know this is an older thread but ive had my machine for over a year and havent used because i cannot for the life of me get it calibrated. Ive decided im bound and determined to get it working so its not just a paper weight. Spent hours and hours. Im to my wits end. Watched the videos multiple times and followed instructions.
Right now my x axis is 313.15 and y- 312.5.
Make sure you reset the Droid back to factory defaults before doing another calibration. Otherwise your compounding errors. Reset and do a calibration.
Be sure the calibration triangle is securely held in place.
@Blethert
Actually those numbers aren’t bad. if you are within 0.5mmover 313 mm you are within 0.1%
