Compact Downdraft Water Table Prototype
  • Mobile and height adjustable
  • Tool-less disassembly for storage
  • Plasma table can be lowered in place and worktable top placed on frame
  • Uses ~2 gallons of water; water pan easily lifted and emptied
  • Airguides/sparkshields contain horizontal sparks from top of material being cut and directs them down into catch basin
  • Adjustable, switchable-magnet base for Arcdroid control panel
To Do
  • Final welding and painting
  • Duct spark arrestor and activated carbon filtration
Seems to work great so far…
Looks good. Thanks for posting the pics. The mag base for the Droid panel mount is a good idea.
Be careful with magnets around the ArcDroid. I had a magnetic ground clamp and it really messed with the electronics.
Any details on the fan?
Good question. It looks like it’s far enough away not to cause a problem. I would keep an eye out for electrical problems.
The blower is a Harbor Freight dust collector that I got on sale and modified. It has a steel impeller for spark rejection. Duct is 4" semi-rigid aluminum dryer duct and various fittings from Home Depot…
  • Glenn
Hi. Thanks for the heads-up. The Arcdroid is plugged into a surge suppressor and on a different circuit than the blower. Haven’t seen any problems with interference from this or the control panel magnetic base so far.
  • Glenn
Brilliant idea on mounting your controller. Thanks for posting pics.
