Connection between Hynade plasma and Arcdroid
I have a Hynade CUT60DN and I’m confused to how the proper connection between it and the Arcdriod should be. On the plasma cutter it has two factory connections, one with two pins called ARC VOLTAGE OUTPUT. And the other with four pins called SIGNAL CONTROL. I watched several YouTube videos and non of them were my combination of plasma cutter with Arcdriod. Any ideas? I’m thinking the SIGNAL CONTROL connector, pins 1,2 because the plasma cutter manual says on that connector pins 1,2 are “START CONTROL SIGNAL INPUT”. Does that sound correct?
Nope check this out
Testing the most affordable CNC plasma cutter on Amazon Hynade CUT60DN (youtube.com)
I’m going to have to watch this YouTube video now, because if the book says start control input is 1 and 2 that’s what your looking for
Yes, after more detailed review of the manual and confirming it with the YouTube video and a post from the inventor of the Arcdroid I would have to say without a doubt that is the correct way to connect between the machines.
