Controller plus issue
I have a plus controller and it won’t boot up when connected to the arcdroid, it starts fine when just connected with a USB C power supply. With the eithernet cable cable connected the only thing that happens is the arcdroid logo screen comes on and then a blue banner that says 5 second no coms then it just stays on the logo screen. The design screen never opened. I did install the power pcb but it doesn’t make any difference.
Sounds like you need to upgrade the coms chip set.
It’s an older unit if that makes a difference
Same age as mine and I had the same problem. Will need a new motherboard to communicate with the plus. The original control gets an upgraded board too if you want to be able to still use it.
Contact Andrew and he will fix you up.
Thank you for the help!
Do you have good contact information for Andrew, I’ve been trying for 3 months to get ahold of someone at the phone number and email address on the website and no one has ever responded back.
I’ve always used andrew@arcdroidcnc.com
