I’m downloading cut files from Langmuir Systems Fireshare but they come up out of the cutting area on the Arcdoid screen, it is pretty hard to move it into the cut area but they cut ok when I can do it. Is there an easier way to do this?
Mark, it depends on where your file has the ZERO point, but try moving your AD to a different spot on your table thru it’s range of motion, then press zero on the AD screen, it should relocate the part based on the zero point in the drawing file to the place on the table you just selected…
I hope that helps !
Mike
