Dimension accuracy’s
Hi I have just acquired a secondhand arcdroid which hasn’t seen much use it came with a Jasic cut 45 plasma cutter and works very well. The issue I am having is with the accuracy of the components I am cutting out. When cutting out holes I have been using the right hand cut and the left cut when cutting external shapes.The external cuts come out pretty close but the internals are undersized. I have played around with the kerf settings but can’t seem to get it right. Any help would be appreciated
Are you changing the cut side between internal and external passes? You have three choices, left, right, center. How much error are you seeing? How thick is the material and is the cut edge angled or pretty straight?
Try fiddling with your Kerf setting
