Drill mode aka "peck a pilot divot"
I use sheetcam to generate G code but when I use “DRILL MODE” to peck a small pilot hole to be drilled out properly later, it tells me the feature isn’t supported by Arcdroid - Any chance this can be implemented at all?
@Matt_UK
that is correct “drill mode” is not supported
However you can just put a hole of tiny diameter… Say 0.01mm at any place you want a peck done and AD will do the same thing
