does arcdroid have a keyhole function im getting tied of having to take everything off my base to weld new gadgets on.
I do not understand what your getting at…….
I’m planning to drill and use nut rivet with a bolt, then cut keyhole slots on what I want to hang, you can set up different tool hangers depending on your job and easily change them out.
Hey @Jdd
No I’m sorry we don’t have that one set up However if you don’t mid a little bit of overlap on you cuts you can easily do it with a slot and a Circle.
Thanks that might just help, I got to stop thinking of off the wall crap when I’m in bed sick. I just thought that it would make in easier to hang projects.
