Feedback Please
Bought a tattered American flag dxf file from etsy…Seller has been fantastic with multiple attempts trying to correct it. Here’s what I’m running into.
When I load this exact file on the Arcdroid it does not have a border around some of the bottom portion of the flag???
Very confused as to why??? I believe it could be the memory capability of the Arcdroid, just a guess??? However, I’ve cut out what I think is more intricate projects and it did just fine…???
I try to avoid using DXF on the ArcDroid for this reason, among others.
I know it’s a learning curve but learning to use basic even CAD software, will benefit you. Often 2D is all you need and you can load a dxf file, fix it if need be, then generate your gcode and take it to the ArcDroid.
I can’t make any promises but if I get time this evening, I’ll see if I can make a cut file for you. Unless someone else gets to it first. Just let me know what dimensions you need it. (And cut parameters in inches? or mm?)
That would be Fantastic. I just started learning CAD for that reason, it’s a huge leap for me but slowly getting it. I hate depending on others to correct files for me. I would like it 23.5" wide X 16" height.
Thank you so much…g code would be fantastic plus I can scale it there.
Thanks Again. Anything you can do Id really appreciate it.
Alright, here’s the file and a few notes.
First thanks to Matt_UK for the fixed dxf, that came in handy and saved me some time.
Dimensions; it was limited by the length so it’s close to 23 inches long.
Origin is top left corner.
You probably already know this but, when you load it up, be sure to change the cut parameters so they are optimal to the material you are cutting. (Leave kerf width at 0) Use the smallest diameter nozzle you can. Because of the narrow details, I had to use some Fusion trickery to make it generate many of the cut paths.
Also, double check it with a dry run. And I usually do stuff in mm but I changed the document type to inches and generated the gcode in inches for this one. It should be correct (the code looks correct) but it wouldn’t be the first time I missed something.
Also, file is 3204 lines of code. It should be ok but if it’s not I’ll shrink it or split the file for you. tattered american flag.gcode (76.7 KB)
FIRST…Matt_UK & Amp_ Mechanic I thank you both for your support. There’s no way I would have ever accomplished what you 2 geniuses have done. I cut out 2 flags this morning and they came out perfect. I even scaled it to 23.77 inches wide… they both look phenomenal. I also increased the feed speed to 140 inches/min and the fine detail was a jaw dropper. Slag was knocked off with my finger nail.
THANK YOU AGAIN FELLAS,
I OWE YOU! YOU HAVE MADE MY MONTH!
