When you Import a .DXF there is a setting for a Global L/C R/C C/C that is applied to all of the lines (don’t forget to add some Lead length)
After that you can go into Trace and edit individual curves by zooming in and selectin the cure you want to change (It’ll turn Red) and then select the “Edit” button. You can then flip the L/R cut and change lead for that curve only
Cheers
AM
