Trying to cut this piece.
That happens when poly lines are used. The interface processor locates all poly lines centers in zero position.
Just pop into the Trace function and edit them
DXF import puts a global offset on the file when you import.
You need to swap the Leads where you need them after the fact in the trace screen
Simply choose the line you need to swap , it’ll turn red, and pick the edit button. you can then swap the lead side
Thanks Andrew, I’ll check tomorrow.
