Got my hypertherm 45 xp to etch using the arcdroid. The hypertherm has “marking “ setting and consumables. Works pretty well, we’re going to make valve box labels with it.
That is pretty slick! I don’t see Marking Consumables listed on the Hypertherm site. Is what your using a gouging tip with the power turned down? Do you know the part numbers of what you are using for tips?
Very good. Thanks for posting the pics. Will have to pick some up and give it a try.
Apparently if you substitute Argon for compressed air the results are even cleaner.
