If your cart or table has angle iron corners or a flat flange somewhere, here’s an easy way to keep your stylus out of the way.
Just hold the stylus mount up to the flange so you can mark out the location of the pin hole, then drill and tap for a M6 or 1/4" socket head screw. Thread a piece of scrap to thread onto the other side of the screw, and cut it to match the inside width of the stylus mount. This keeps the mount from sliding out & off the socket head.
