I have tried 2 different laptops, the one I typically use threw the error, the graphics driver is current. I tied my work laptop which is built out to support VMs etc, and is about 6 months old, same thing. Tried a new design etc and still the error. Looked online for anything I could find, there are a few things to try but nothing seems to be working. Anyone else run into this and if so did you find the fix? Thanks
No one else has run into this issue?
Hey John
You should probably check with the Fusion360 people. They are much more likely to have an answer for you
Good idea, thanks Andrew
