Currently I have the archdroid working with my Everlast 52i via the CNC port, but the hand torch set up ie going back and forth is a pain is the butt. So I purchased a IPTM-60 straight torch to be dedicated to my archdroid. My question is, what is the pinout mods I need to do, if any, to allow me to swap between my hand held torch for cutting and switch in my dedicated IPTM-60 torch for when I am using my Archdroid? Any help would be great, thanks in advance for your help.
No one? As I understand it the important pins are 4 and 7, still no luck
Everlast 62i user here. Using the same torch but utilizing the CNC port in the back of the machine. 18 ga 2 wire soldered to 1 and 2 pins on CNC plug. Hopefully this helps
I made the same conclusion, I wanted the wires pointing up and hanging from a hook on the ceiling. Swapping from the hand torch to the CNC torch is a nice feature since you don’t have to disassemble the hand torch. pin 4 and 7 are correct. I had a successful run last year and put it in storage. I tried running it again last night and it didn’t work. I had tech support on the phone this morning trying to troubleshot it as the hand torch still worked and the CNC torch was the culprit. We walked through many scenarios and he concluded that it was me clamping it on the bottom portion on the torch. It must be clamped above that, away from the sticker and the 4 torque screws. If you have it wired up so the hand torch works and the CNC doesn’t, I would conclude that you have a dud like mine. Unfortunately I passed the warranty point and I’m stuck with this lightly used delicate flower. I highly recommend anyone here to learn from my mistake and not go this route. If you already made the purchase, make sure you clamp it up high as any pressure will foul the movement of the electrode. Also, If you bought it try to break it before warranty.
