I am not sure how many Times I’ve accidentally deleted a shape and had to start the process all over again, but it’s not fun! I would love to be able to undo the undo. Anyone else agree?
Or if you stop in the middle of a cut and cannot restart where you left off…going to the beginning of the cut just doesn’t work well.
I 100% agree. Even one false-probe can easily ruin your work. Pausing only interrupts the cutting process in between functions, leaving you to abort the entire process alltogether and having to delete already cut shapes as a sad alternative to simply resuming the process. And once shapes are gone, they are GONE to the 9th dimension!
if you have to stop mid cut as long as you dont reset the the zero point turn off the torch on the arc droid, run the program as a dry run until you get to where you stopped the cut and then turn the torch back on to continue cutting.
