Machine torch for a Titanium 65 plasma cutter
I am wondering if anyone has come out with a machine torch for a Titanium 65 plasma cutter!
I bought a replacement hand assembly from HF parts. At the time it was cheaper than any ebay option and replaced the handle with shedule 40 pvc. The pvc is easily softened with heat and I modified the copper tube with a more adventageous angle. I would recommend a lighter pvc as I used a lathe to reduce is weight. So I have the ability to swap out in ten seconds and its oem.
