2" cut height or 2 mm…you are using both units in the same sentence.
Hopefully that MM, I think the speed ( too fast) is the issue, possibly ground location?
Also fresh tip/electrode helps a bunch
Playing around in sheetcam you can set cut rules to vary the speed for different parts of the cut which would help in a file like this, but they don’t transfer to the droid it seems after a few tests. It picks up on the first speed and stays there.
Be interested to know if that’s something that could be integrated into future updates.
I posted a query about editing saved simple trace files. That topic would be helpful
A bit more detail per topic might be helpful, Often can;t see what;s being pressed on the UI
@arcnc Yep that’s on the next filming list!
