Why is my Arcdroid drawing at an angle?
Image should be straight, not crooked. what am i missing or doing wrong?
any help will be greatly appreciated!
Is it crooked on the screen in reference to the work borders shown?
Maybe try changing the ref zero and shift the work to another area.
If you do a simple trace of a rectangle, does that stay parallel to the Droid base or is it crooked too?
Ok. With your program loaded, tap Trace. Then tap the box with two triangles and arrows.
Look at box A in the menu that comes up and see if a number other than zero is there.
