Too bad there isn’t a Padded footlocker for safe transport, hint hint.
Foot lockers are just plywood and hinges. Padding can be found a lots of places. You can go to Ulinie and buy some of the 2 part self expanding packer foam kits and make a mold to hold it tight. If you look around on the government surplus sites you could even find an affordable pelican case in most regards.
I’m told the ArcDoid will fit in a Pelican 1607 quite comfortably
