The Eastwood cut n weld plasma table top has got to be the easiest solution. The thing is only about 70$ and it mates up to your various 3x2’ welding tables almost perfectly. I made a pair of rails that integrate with the weld table for a quick cutting table. The rails attach the opposite direction for storage and the slats portion has hangers for stowing on the end of the toolbox. My Arcdroid runs a laser so the fume generation is somewhat less than with the plasma, the water table is not really needed but something could be rigged underneath if wanted. I place a portion of backer board on the ground to absorb the laser light. Elsewise the concrete gets a little scarred.
